CMF_zfind
» CMF MemberHi guys,
This is my first post here after picking up a '95 K11. She's a great car with only 92,000km and is in mostly good condition, however a few little things need doing.
The most important at the moment are the rubber steering boots. Both sides have split open and sprayed grease everywhere (fun to clean off). I've gaffer taped them closed as a temporary solution but I know I need to get them replaced a.s.a.p. They are the boots just behind the wheel hubs, not the inner CV boots.
What I'd like to ask is, how hard is it really to replace these? I'm pretty good with cars but have never done this before. I've got the Haynes manual but it seems very complicated for what it is. This is what I found on MSC:
"ok take the wheel off,
undo the big nut on the driveshaft,
undo the 2 suspension bolts that go though the wheel hub you may have to remove the clip that holds the brake pipe to the suspension,
then move the hub down and push the driveshaft out
if the driveshaft is tight put the big nut on a few threads and give it a wack that way you wont damage the threads"
Is that all there is to it? I got the split pin out but not surprisingly, couldn't budge the driveshaft nut. If I get a breaker bar and get that off, should I be able to do the rest fairly easily?
As a note, I've just done the gearbox fluid - replacing the outer boot doesn't need the driveshaft to come out does it?
Thanks and sorry for the longish post
