SteveG
Intake n exhaust almost done, suspension next :)
I've replaced the front suspension with KYB Excel-G K11 shocks and HOL tarmac springs, and rear suspension with KYB Excel-G Corsa-B shocks and HOL tarmac springs. Springs are 50 and 60mm drop.
I'm determined to get the Noddy adjustable panhard rod on to sort the back offset out. But what is much more noticeably affecting the handling of the car is that the steering centre is offset by about an inch of steering wheel circumference and the front wheels have visible toe out.
At some point when I have time I'll take the car to the garage to get the wheels aligned properly, but in the meantime I'm hoping to get rid of the toe out and hopefully also correct the steering centre.
I know I can adjust the toe angle by adjusting the tie rods equally, but can I also adjust the centre point by adjusting them different amounts/directions?
I spent about half an hour looking for my Haynes manual and I have no idea where it is, and all information I've found so far on how to adjust toe seem to assume that you already what you're doing with the tie rod nuts and whatever spins around.
Maybe it will make sense once I get under the car and look for the tie rod nut and start turning stuff, but in case it doesn't, anyone got any pointers? Adjusting for toe seems straightforward in principal (probably tedious and iterative in practise) but I'm unsure about the centering?
Edit: found the FA (Front Axle) section of the workshop(?) manual on dropbox... I think it says how to do it all
