steerign wheel boss
Belly93
to turbo or new lump :/ hmmm
im looking for a boss to fit an aftermarket steering wheel but i can only find non airbag bosses and my 2000 k11 has an airbag can anyone tell me if theres a difference in the two bosses or where i can get one to fit my car? thanks in advance Adam
so i should be good with one like yours karl? and i was thinking quick release kit would a shortet boss be better as i dont want the wheel to close to me
I'm using a non-airbag boss on my previously airbagged '98 SR. It works exactly the same as the others, except you might end up with the airbag light coming on. Just put a resistor on the wire or remove the bulb. The kit I'm using is only a cheap £20 eBay one and it does the job aswell as any £70 one :D
Also, a snap off kit goes in between the aftermarket boss and your wheel (except for the ones which fit to the spline), so it will bring the wheel a bit closer to you.
