Steel Wheels on my K11
Evening all,
I'd like to fit some 14" steels from another car on my K11 and lower it. Has anyone reading this done this mod? I've been looking here: http://www.carlsalter.com/wheel_fitments.html and it seems the VW 4 x 100 wheels have the right offset but the bore is 57 and needs to be 59 - is it as simple as opening up the bore as we have a decent machine shop at work that could help.
Also, having had a look on the bay ot seems 14" x 6" is as wide as standard steelies on other cars goes - how will this look in the arch. I'm thinking a 185 tyre would help fill the arch, but i'm guessing a small space may be needed to look good?
Any help or advice on standard wheels I could look for would be great. I quite like the look of the Mk3 Passat 14" steel (http://www.ebay.co.uk/itm/VW-PASSAT...s_tyres_Trims_Car_Rims_ET&hash=item4cfccd7c5a) as it looks similar to the Weller steels, or the G60 polo wheels look good too.
Cheers,
Alex
i opened up my golf ones with a grinder alex, if you use a well worn stone it fits inside np :) (no use with alloy wheels tho, coz it clogs the disc eh)
