I have had starting problems. I suspected the dizzy but now I am not so sure. I read somewhere to check for over-fuelling. I removed the fuel pump fuse, cranked the car a few times and then replaced the fuse and - BINGO the car starts first time. Each time the car fails to start, if I do this procedure it works.
But the thing is I don't understand why it works. I mean obviously something is broken and it is a common thing (hence the advice I found on the NET). Can anyone tell me what it is that is broken and needs to be repaired in the long-term?
