starting problem
CMF_garrethk11
car will not start. the car was stolen and the ignition wires left connected all night so i charged the battery as it was dead but the car wouldnt start so i then replaced the starter motor and still no start is there any fuse or relay that i can check any help would be great by the way the car wont even try to start all i get is dashboard lights
CMF_frank2
so its getting no feed then eh, it not getting linked to the ignition switch then.
but if it wont bump start either, then it could be an ecu feed etc.
there is an ecu relay near the battery (next to the fan relay) does that click on and off ?
