when i go to start my k11 it will sometimes take a few seconds to start (it sort of like mis-fires but doesn't if that makes sense) when i turn the key full to start, but then when i go to start it again it will start perfect.
Ive changed the spark plugs, changed the negative and positive connection on the battery because they were cracked, clean the white foam off the top of the battery, cleaned the battery pan and hammer righted it.
my dad seems to think i need to clean the starter motor could this be it?
or is it something else
thanks a lot
John
thanks a lot
John
