problem is its a bit hard to start, hot or cold, but once it has it drive perfectly and doesnt cut out.
i have read alot about this problem and im totaly confused as to what it is.
list of problems it could be by other people:
distrubutor cap, ecu, feul line, throtle body, spark plugs, fuses, commom fault with micras, feul pump, spark plug leads the, wiring looms that i think were changed by nissan in 1995.
i have checked a couple of thing, like the fuse in the fuse box near the battery that could be suspect and sure enough it had but already been repaired and i have also noticed the feul filter had been replaced by a bit copper pipe that i am goin to change back.
can anyone help and give me the advice i need and how to diy repair it if possible, im a bit terrified to go to a nissan dealer and get bumped.
thanx
thanx
