just curious about what needs doing to fit a starlet intake? Where the vacuum pipes go? And if the throttle body is a straight fit? Any info is appreciated
It needs cutting and welding to the micra manifold near the fuel rail, vacuum lines are quite probably different and it needs a plate welded on to adapt to the Cg13de throttle body.
