coilovers it may have to be then.....
how much roughly should i be paying from a breakers yard gents for the whole suspension units front and back
cheers
the 175/60's offer good visual stance but are rubbing on rear due to funking panhard rod, need an adjustable one, i got rear tuck and rear poke!!
frank is it possible the rear matiz shocks fit in ok? much work to get em on, i read about the front and they seem quite straight forward, was thinking some decent 35mm lowering springs for them to get round aboout 80-90mm drop?
what sort of height would you get with micra fronts in the matiz legs? could you cut em to suit - that way you would get stiffer springs and better damping - all in a shorter strut body.
no mart the matiz shock has eyes top and bottom iirc (and i hav,nt found a suitable shorter rear shock yet :wasntme: )
mine were shortened and re-threaded eh, but they,re damned hard steel tho and they take some threading
does any one know the length of a stock shock on rear frank/mark?
wanna do a search for cars but need a height to see whay im working at please
cheers
my shortened ones are 440mm mart (center of rubber to center of rubber) i think they were 560mm originally
so you removed 120mm of your stock shaft??? that sounds to much?
