And what do you mean when you as "Which side should you have the power cable and signal cable"? I also take it you mean the blue remote cable when you say "signal". Because the power cable obviously connects to the positive battery terminal. And when you connect the cables to the back of the sub/amp, they should be labled - PWR = Power, GND = Ground, RMT = Remote, or just the initials, so P - G - R. Power cable is also normally red, ground is brown, remote is blue, and you should have at least a 60 amp fuse somewhere along the power cable.
Also make sure you connect the power cable up last, as it is very easy to short out the system when you connect the ground cables (which you'll need 2 for - 1 for the sub, and another for the amp, and the same for the remote and power cables. It isn't safe to bridge them).
No, the power cable won't melt if it's in the engine bay. Just make sure you zip tie it to the side of the bay so it doesn't flop around too much. I made up some brackets to hold the fuse and cables out of the way, but strong zip ties do the job. Have you also found which rubber grommet to go through in the engine bay as well?
yeh dont let the live cable get cut at the side of the growmit, pass it through it
good good, yeah ive found the grommet
ive just got it sitting in the hole and put the grommet over it so its pushed against the side. is that good or bad??
