Squeaking Noise
CMF_ChrisB
Hi Everyone,
I am getting a squeaking noise when I suddenly come of the gas in first gear. The car jolts abit and their is a squeaking noise. This does not occur at any other time. Any suggestion would be great.
Thanks Alot,
Chris.
CMF_Campbell
sorry to bring up an old thread but think i have the answer, the cross member under the engine has two main bolts at the front, and at the rear. The two bolts at the rear have two collars and rubber washers, make sure that they are both properly screwed in and tight, if they are not it can cause movement in the gearbox, hence when you take your foot off the gas the gearbox will move forward and squeak.
