CMF_yoyoninjaboy
» CMF MemberHey, im now stuck with a bit of a dilema and need some help.
i recently purchased a set of front spotlamps off ebay. through no ones fault but my own they do not fit. i overlooked the exact modles that the lamps would fit and went only on what i could see in the picture. as it turns out they are for the new frog shaped micra.
ok, no worries, i can adapt them. but where?
i have had a few ideas on where i can mount the lamps. now bear in mind they are not normal lamps so i cant stick them on the front of the bumper, they have to be set into a hole. but they 'are' round (kind of).
i was thinking mount them in the holes i in the bumper where spot lamps are meant to go and mesh over them, either mith a hole cut out for them or without.
but then i thought about mounting them in the bonnet grills and again using mesh to fill around them.
any ideas or thoughts welcome!
ill post a pic of the car so you can see whats available.
Cheers Nick
Cheers Nick
