sportmax wheels on k11
CMF_xsoarerx
its will be very (refer pic)
your safe bet will be the 15x7+38? odd rims they sell
CMF_deNs
bongo bus WROTE:
"i dont get it???
8J +0 = Mexican stance, otherwise known as poke, or sticking-out-of-the-stock-guards-a-****load-itis.
With 15x7 +15 you probably won't have to do anything to the front, but the rears could well scrub unless you roll the guard lip.
---dens
CMF_xsoarerx
i got 14x7 -8 on the front of my micra. 10hrs of decent guard work in the front alone... also im running -5 deg of camber...
so 15x8 0 is about 15mm futer out and my fron guards are pushed to the limit
and will sit about 10mm more futher out with 0 camber.
and stock guards will be even futher!!!
CMF_adz14
^^^^ so what was needed on the guards? Roll/flaring/inner guard?
I am hoping to squeeze 15x8 +25s all round. Not keen on running more than about -3 camber.
CMF_RoadsterGarage
Won't work.
You should be able to squeeze in a 15x8 +25.
I had 13x7 +12 wheels on my micra, All I did was roll the guards. It all comes down to tyre choice too though. Don't expect to run 225 with those wheels, I'm thinking a 195 will cut it.
