yeah, fit the spigot rings, the flat side oes against the hub, then the wheel goes on after it, and the centre bore should fit nicely with the spigot ring
Is there any real advantage when you do fit them? It's unlikely there would be any play between the wheel and the hub as the wheelnuts are tightened up which centralises and secures the wheel.
