CMF_super s95 » CMF Member VIC, Australia Member since: Posts: May 18, 2011 #1 my super s speedometer just stop working last night... do i need to buy a new part or can be fit it... if i do need a new speedometer, where i can buy one which would fit for super s..? thx
CMF_1300cc » CMF Member melbourne, victoria, Australia Member since: Posts: May 18, 2011 #2 im assuming you have done the obvious, like, removing the instrument panel and see if the cable at the back of the panel is not loose....or you can check this one as well http://nissan4u.com/parts/micra/er_k11e/1995_10/type_19/power_train/speedometer_pinion/
CMF_Rudy » CMF Member Hunter Valley mob 0400767960, NSW, Australia Member since: Posts: May 18, 2011 #3 if it is faulty u should be able to take centre from a 2nd hand std cluster and install into sup.s cluster, check speedo drive and cable first
