Speedo drive help
My car aboult 5 weeks ago killed it's speedo drive and I was driving home tonight and it killed a second one the first time it went I was starting to break from aboult 60mph and the second time I was doing 75mph overtaking someone and it died again just like the first time is it a common fault on micras or am I having bad luck
Specs are a 1.3 engine with 1l gearbox and 15" 7j alloys
Pull it out and then spin the gear with the ignition on and see if the speedo works then, if yes the sensor and wiring is fine and is a fault in the box.
This was the old one looks fine I felt the gear inside the box that felt fine aswell so I'm lost as what it could be
