Courior said:
They're basically Average Speed Cameras:
[FONT=Arial, Helvetica, sans-serif]
[/FONT]
SPECS System
Speed Violation Detection Deterrent, SVDD is the digital brain which the SPECS system is based upon, it uses state of the art video system with Automatic Number Plate Reading (ANPR) digital technology. Consisting of two video cameras each fitted with infra red illuminators, giving the ability to work 24hrs 7days a week.
SPECS are fitted either at the roadside or central reservation a set distance apart to create a speed controlled zone, or where appropriate, groups of cameras can be linked to create a speed controlled network. Mounted to a single or doubled armed distinctive blue SPECS column, they are linked together via computer.
As vehicles pass between the entry and exit camera points their number plates are digitally recorded, whether speeding or not. Then, by ANPR recognition, the images on the video of matching number plates are paired up, and because each image carries a date and time stamp, the computer can then work out your average speed between the cameras, and then will make a decision if the preset speed threshold is triggered. This data is then digitally stored on a central computer, so that there is no need for film to be collected and changed at the cameras site. Pictured above; a SPECS system sited on one side of the road, used to enforce speed in both directions.
SPECS is currently in use in permanent sites in Nottingham, Gloucester and Northamptonshire and in temporary locations in Cheshire, Kent, West Midlands and West Yorkshire.
