spark plug leads
CMF_sojah
can i get some advice on wat is the best (mm) spark plug lead i can use on my super s. Is an (8mm) lead ok and if so, wat make of lead do you suggest. I was told tthat these are very good. Electrosports Cable (8mm).
CMF_sojah
Hi, can i get some advice on wat is the best (mm) spark plug lead i can use on my super s. Is an (8mm) lead ok and if so, wat make of lead do you suggest. I was told tthat these are very good. Electrosports Cable (8mm).
