I saw a set of Sparco pedals I liked on Cisco's site and bought a set on eBay.
Installation was pretty straight forward for the clutch and brake pedals (off with the rubber pads, drill two holes in each pedal, attach, etc.) but the accelerator pedal was something else. The plastic pedal that is attached to the rod is too thick for the Sparco screws and lock nuts. So out comes the assembly and after taking a few measurments and making templates, I welded a heavy guage strip of sheet metal onto the rod, ground down the welds, drilled the mounting holes and sprayed it black. Looks almost factory.
I'm a little annoyed about the clutch pedal being a little higher up, about 1/2", than the brake pedal and might have to deal with that another time. For now, however, I'm pleased with the look of the pedals: a little something extra without being too over the top.
S
S
