some question about turbo
hello,
I'm thinking t build a turbo to my 1.3 k11 micra and i have some questions
1/which is the best turbo kit can fit it and how much would cost approximately
2/ how is the maxiumum psi can run with no problems for the engine
3/ I need to replace , injectors, fuel pump, exhaust right ? and what else?
4/ how many hp power would the turbo add to the car
i hope u can answer my questions
There are no currently available commercial turbo kits I am aware of, turboing a micra is either a DIY affair as far as manifolds and fuel rails and the such are concerned, or you should wait until another member is selling their setup. The highest power I've seen is @Stani's last build at 160hp, I think that was with stock internals? Pretty Sure @PollyP's is at 160hp too but thats on a forged engine (although I think that turbo setup ran on stock internals too?).
Polly and Stani have good blogs with regards to turbocharging.
I c , so I need to do some modification
so what about Chinese 300watt electrical super charger does it really work? and how much HP can increase?
do u mean like this one
http://www.aliexpress.com/item/Turb...lopper-2-5-TD-with-4D56-Engine/583737842.html
how much does it really gives extra 88 hp to the engine
does it need diy work or it's easy to install
its the one i was running for most of this year :) http://www.micra.com.au/community/message.php?messageid=81154
