CMF_Yom
» CMF MemberThese are just some pictures of the old clutch and flywheel compared with the new clutch and flywheel.
New clutch is a LUK Heavy Duty item for the Micra. It has roughly 15% stronger clamping force than the factory LUK clutch according to Jim Berry @ Race Clutch in Brisbane.Jim reckons LUK clutches are very high quality - typically of a much more consistant quality than the common Daiken/Excedy/PBR clutches that are used on a regular basis in Australia. He also reckons the organics can withstand higher clamping force than the competition but you'll have to call him to find out more about that. Every spec he said was in old school units and I can't remember them. The LUK HD clutch is only a few more $$ than the repco available Daiken/Excedy/PBR and I reckon it is worth the money. If nissan used LUK's from the factory they must be half decent.
New flywheel is a second hand unit from Wreckers which has been machined and also lightened by approximately 1kg. Majority of the weight was taken off the rear behind the rear plate (micra fly is a 2 piece, like subaru clutches).
Anyway here are some pictures. In this picture you can see the new purple LUK HD clutch and the old one.
