davey1991 If its not scrubbing, its not low enough. Mar 7, 2012 #1 Right seems some have done this but i'm struggling to understand where and how??
OP OP davey1991 If its not scrubbing, its not low enough. Mar 7, 2012 #3 I'm confused now, i'm sure someone mentioned that the ga16 TB doesn't have one so they soldered the one out of the micra into it?
frank Club Member Mar 7, 2012 #4 i cut the CG idle control valve off and mounted it remotely if thats what you,re thinking ?
OP OP davey1991 If its not scrubbing, its not low enough. Mar 7, 2012 #5 nope someone was going on about it not having an intake air temp sensor and it being hard too map... meh im lost maybe i should have just left it on... How hard is it too fit the sr20 TB??
frank Club Member Mar 7, 2012 #6 davey1991 said: How hard is it too fit the sr20 TB?? Click to expand... you need an adaptor plate, and also mount a maf upstream (there are pics in my cisco threads)
