Pretty easy to check the seals, just get someone to put the pedal a few times and let the piston out, inspect the seal and give it a shot of wd40 if you're not stripping then down yet. Then use a g clamp to fire the piston back into the caliper
Sent from my SM-G900F using Tapatalk
