CMF_david (2)
» CMF MemberHi all,
I have been experiencing some problems with my micra. My micra is dual fuel, but the problem only occurs when it runs on petrol. The symptom is that when under light/medium acceleration it sort of skips/hops/jerks along slightly.
After talking to various people I thought it might be the injectors are dirty, the O2 sensor might need replacing, or the timing might be out, or it could be dirty fuel.
So I used up the fuel tank and filled it up and it kept happening...so not dirty fuel.
Took it to the mechanic...who put it on his tuneup machine and said it was all fine (charged $110 ) and then said that it left the injectors or the O2 sensor which he said normally need replacing about the 100,000 kms mark anyway. (I have about 90,000) We then decided to put some injector cleaner stuff in the tank and try that...I am about 1/2 way through that tank and it appears to have improved it...but I can still notice it ever so slightly. Thus, I am thinking that I will need to get the injectors cleaned properly sometime in the near future.
Ideas/comments welcome. Or maybe at least it will save someone $100 for a tuneup that is not needed. ($25 for injector cleaner stuff... that he said was very good.)
