Hello!
I have huge request for you guys, mine sills looks bad, but outer panel is quite okay. Divantage of this is I cannot look inside to chceck how side sill and floor panel is connected...
also cant just cut the hole tomorow, because car is still in use, have to make a plan (of attack) first.
the whorst place is outer panel end (car jack place), behind it is part of floorpan that looks like L-beam. I want to repair it with builders L-beam for strengtening, but dunno is there anything under it to weld...
I had problems with nomenclature, we calling whole part where you can putting the car jack simply as "doorstep"
if someone have work in progres photos of sills/ floorpan repair I will be thankful
attached schematics, the "?" is main area
edit: joining place, sorry for that I'm not smookin' weed everyday
