Silicone hoses - recommendations?
hoodedreeper
Hello!
I'm in the process of relocating my air filter and i need a silicone hose 90 degree with a 75mm inner diameter.I've been quoted by a local company 30 quid for one to be specially made as i want it red (they always stock blue).I've looked online and failed to find anything.Closest was 76mm and was the same price.
Thanks in advance!
the pipe leading off the hose is 75mm...what could i do to bulk it out abit so it fits inside the hose (as the hose will be 1mm bigger)
the one linked on ebay...it says 51>76...does that mean one end is 51mm and the other 76mm? or are both ends the same size?
the first link is a reducer from 76-51
the second is just an elbow
I just bought a 90 degree 2.5inch, aluminium intercooler pipe, that way I can drill a hole and bolt it on with the standard carb bolt. Then shove a bit of pipe on the end of that.
