Courior
Fat ppl r harder 2 kidnap
I have done a search and cant find the answer so here goes!
I have extra lights on my car like Arnold. I had them wired to a switch that was active with the ignition, so i could turn them on/off independantly of all other lights as long as the ignition was on.. this is rubbish and so i want to wire them to the FULL beam circuit (when the blue light appears on the dash). I got my dad to flash the headlights while i stuck a tester in each pin on the bulb connector and found the active one. I spliced into this with the wire to the relay switch and then they came on when i flashed the headlights.. GRAND i thought... I went for a drive and when i put my sidelights on the driving lamps ALSO came on.. then on dipped beam they went off... then on FULL beam they came on as planned. I have been having a look and for some reason when the car is started the main lights seem to come on SOOOO faintly with the sidelights. This little bit of juice is enough to trip the fog lamp relay and activate them.. (sorry to go on hehe) Where do i find a wire that is active ONLY when the FULL beams are on? (pics will help)
Thanks in advance!
Courior
Thanks in advance!
Courior
