Side Lights Help !!
So I came home this evening and when I turned my engine off and lights, the sidelights and internal light stayed on.
I started to experiment to see what the problem was. Disconnected the battery, Checked fuses. I then tried to turn the main beam back on and they did not come on. The high beam did not work when i pushed the stick back, but worked when i pulled it forward. I checked a dew other things due to me having a H.I.D kit.
I then started to look at the stick. I removed the stick and the two connections and the sidelights went off. It was the top connection that turned the lights off.
Would you suggest replacing the stick? I have to remove the stick connection or the lights wont go off.
