does anybody know where the side light fuse is in the fuse box, checked under bonnet and under steering boxes, none of them are for the side lights and manual says jack all so stuck as i have a side light out and need to fix the fuse back!
cant seem to find the fuse tho, i need to look at the fuse to see if its out or not, but no one nos where it is
andy i will get a picture of the exact location of the fuse tomorrow as i need to change a fuse in that fusebox
basically if you look underneath the passenger headlamp you will see a white box this is the fusebox
seems easy eh
well the fusebox is actually mounted upside down so you can`t just lift the lid off and twist your hand round to change the fuse
which means removing the headlight
to do this there are three bolts the two you can see underneath the bonnet and one in the arch to get to the one in the arch you will have to remove the arch liner and the bumper
the fuse is a 10a mini blade fuse
have fun mate
thats how i looked! pretty much a ballache with headlight screws. got many scratches and cuts from gettin the under arch screw lol!
ye if you could take a photo and see if you can find the fuse for the sidelights and ill look again on mine see if it is that fuse or if not, surrendering to nissan = rip off!
