Side Door Trims ---------------------
Hi easy is it to take the side stripe rubber trims off, i was thinking of either colour coding them red or take em off completely.. any comments would be appreciated.
J
Use a hairdryer to heat the glue underneath then some floss or an old guitar string underneath to cut the glue and pull off.
Hi scott, thanks for that but once the trim is off what about the double sided glue, how would i take it off the door, what i mean there will be bits left on there and as the car is an M reg its probably gonna be a Bit-c to come off if you now what i mean!!
