Shock Absorbers
Hi Craig,
The model number VNE-4481 seems to match the one I had when I once fitted the Bilstein streetline kit
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/#post-381108
k750-438-jpg.33312
k750-437-jpg.30798
Thanks Pollyp, sorry to ask but would these fit a facelift model ? are there any differences between pre-facelift and facelift shockers ?
far as I can tell on nissan4u.com the main attachment points n nut/bolts are the same between facelift n preface.
the only minor part # differences I'm guessing are different hose/cable brackets, shock valving and spring rates/spring seats (between the lighter low-spec models and the heavier high-speced models with PAS & aircon) but you'll be changing the whole shock assembly anyway.
