My friend currently has a K12 and has the service light on at the moment and is looking to turn it off. Not having the manual, can someone explain this process to me?
All I know is that it is a keyless entry model, if that helps!
new facelift k12 (2005 onwards with the service reminder in the dash) you have to do this quite quick, when u put the ignition on it says how many miles until ur next service when u see this number press and hold the trip switch until it starts flashing then u push it until 12000 comes up because this is the service scedule.
pre facelift k12 2003 onwards (computer above stereo type) press menu when u see maintenance press ok then u should see service just press and hold ok until set next is displayed (it takes about 20 to 30 seconds) then press set next. job done.
hope this helps
ps not all early micras have a service reminder unless u have a computer above your stereo
