Hi there,
going to do a service on my girlfriends 51 plate micra 1.3 and just need little bits advice.
Got this stuff:
engine flush
oil
oil filter
air filter
fuel filter
spark plugs
pollen filter
brake pads
discs
brake fluid
anitfreeze??????
washer fluid
gearbox oil
wipers
Going to get a PCV filter, somehow
Anyways, is everything above the main most major stuff I need to replace etc? Can anybody advise if im missing anything or is there anything particular important i should be doing/checking?
DO i need to replace power steering fluid?
Reason for ?????? on antifreeze is im confused. I've read on here a thing about using pink stuff and not to use blue as it can cause damage, is this correct? To me it's the same stuff?
In the past, i've changed her coolant after a radiator leak which is actually still there but only small now. And i've been using Carplan Blue Star antifreeze. Is this stuff ok?? Also on here somebody said antifreeze should contain ethylene glycol but this carplan stuff doesnt seem to have it. HELP!!!!
Got this stuff:
engine flush
oil
oil filter
air filter
fuel filter
spark plugs
pollen filter
brake pads
discs
brake fluid
anitfreeze??????
washer fluid
gearbox oil
wipers
