Same fuse blows on the ipdm each time
hello
this is i think the fourth time that this has happened to me.
a fuse blew on my ipdm and it's always the same one. (something to do with reverse)
at the same time the led t10 led bulb for parking light blew up too. i removed it as well as the other to avoid any conflict that may arise. you may wish to note that the engine won't start if the fuse isn't replaced
i change the fuse afterwards myself cuz i knew it was that famous fuse which blew up as when i went on reverse mode, no sound could be heard and the lights 'R, N, D' on the dashboard went off. i remove the headlamp to get to the ipdm and change the fuse. last time it went to the auto electrician and it costs me quite a sum just to change that bloody fuse.
should i be worried?
i don't know which is the cause, do you have an opinion? has somebody encounter same problem where same fuse on the ipdm gets blown way.
i don't have much modifications on my car, except for an aftermarket head unit and speakers + HID.
thanks
regards
