S14 Fuel Injectors
CMF_White Knight
THe 1.6lt one. Came out around 1993. I am trying to source them out of New Zealand as there are many many Primeras in N.Z. but not sure if they had the 1.6 lt or started with the 1.6lt .
NZ-aj can you help???
CMF_White Knight
P10 model running the GA16DS motor,1600cc motor. Built 1991/1996. Yes injectors 185cc v Micra 135cc.
Trying to source out of England from a wreckers.( sorry auto recyclers to be politically correct)
cisco
I have two complete sets of injectors for sale.
S13 370cc/min turbo injectors perfect condition recently cleaned. $100 for 4.
S14 around 440cc/min injectors good condition, not sure when they were last cleaned. $80.
Modified S13 silvia fuel rail to fit a micra (has slight leak needs some braising to fix the leak) $50. This accepts either of the above sets of injectors.
cisco
Yep see if knight wants them, otherwise fred you're next.
CMF_White Knight
I have bought the fuel rail and S13 injectors.
Going into White Knight.
Now Errol is going to bring in some Nissan Primera injectors which are a direct fit into the standard Micra fuel rail.
cisco
Yeah ok sorry about that.
I still have the S14 ones which just need to be cleaned (I guess) never used them. But got them out of an silvia rail (which I still have aswell). But its a stock silvia rail, i.e. not modified yet, but you can cut and shut it.
