well tonight with my MOT tomorrow the idle went up the creak today (again)
so in a fed up with the car kinda mood i removed and bypassed the cold start which is fine...
however started up and the idle is sticking again so i then removed the IAV again and recleaned and recontred so theres a little gap showing again
fitted again with a little silicone sealant and making sure the rubber o ring is there...
so started up and the idle is everywhere i left it for a bit and it settled but still erratic and a high idle
then i set the idle speed as the side with the 6mm hex all the way to nothing
and its still high... and erratic
so then the stop for the trottle cable loosened that off a little but cannot tighten as its broken as its so weak!
but its still erratic this is getting pointless!
can i remove my tb and tie it to the tow eye and drag it on the floor in disgust (damn i cant as with no tb cant drive!
please help
if anyone has the part number for the IAV ill get one
please help
