CMF_AdStar
» CMF MemberHi Guys,
I must admit I don't actually own a micra (don't hate me or run away). What I do have is an N15 GA16DE Nissan Pulsar.
I managed to source an RS5F31V gearbox with it's 2 drive shafts which I'm sure more of you know is a straight bolt on upgrade to VLSD for the GA16DE motor in the pulsar.
What I'm in need of is some help in sorting out a drive shaft issue. The shorter passenger side shaft isn't a problem, I just swapped them over (and it was very different to the factory one). The problem I have is the shaft I was give for the drivers side is identical on the wheel hub side and the length, but things go funky on the gearbox side.
So in short I was wondering if anyone has the FSM for the K11 that includes the break down of the RS5F31V transaxle + the front axle breakdown (which would give me the spline lengths etc)
Cheers and thanks in advance
Adam
Adam
