Courior
Fat ppl r harder 2 kidnap
I hope you can help me!
I have the SS which is 1.2 and has an ecc carb.. above 3k revs its fine and pulls/cruises smoothly. but under that its a bit different. It idles rough and you can clearly hear it missing a fire every now and then. when cruising at a steady speed the missfire makes it slightly juddery, and if i am cruising at say 2.5k revs and just put my foot down it bogs down and accellerates not as quick as it should then at 3k starts to pull stronger. it only does this if im cruising then accelerate, if i am going from a standstill it pulls no problem. Now, what could this be.. there is only 46K on the clock so its not old. and Fordy has done a MAJOR service inc timing belts and everything. i did change all electric components EXCEPT the rotor arm. and still the same. I first need to work out if its an electrical or fuel problem. one theory i had was the oxygen sensor is bust and therefore the car is being fueled badly (it does drink more fuel than it should slightly).
any ideas welcome!!!
as a note: problem is apparent hot or cold.
