Rough idle
CMF_tommykmicra
When I start my car it is only running on 2 cylinders. I have spark in all 4 clyinders. I think I have an issue with my injectors because after I shut off the car, I checked the plugs and they do not smell like they have fuel on them. Is it hard to remove the injectors and clean them? I had been away for a few months so I was unable to start my car on a regular basis so it is possible that they are clogged. Any suggestions would be greatly appreciated.
OBTW, it is a K11 Tommy Kaira edition if that makes any difference.
CMF_frank2
tommykmicra WROTE:
"Can you explain to me how to do that? I only have basic mechanical knowledge. Thanks.
you will probably need to remove the heatshield from the exhaust mani, then test how hot each runner/primary gets while its running on 2 (wax crayon or whatever) :)
