Rota alloys
im not a fan of 15'' on micras, although its up to you :)
personally with rotas / superlites etc, id prerfer to have standard 13'' tire stretch and poke
I really wouldn't recommend it. There was a chap on here outside of the UK running 15x8 ET0 Rota Grid Vs and he had to fit over arches + run tyre stretch
If you're dead set on getting 15s, here's MikeyRocks' gorgeous K11 on 15x7 ET20 Rota Grids. Note that he's running a ton of stretch to pull off the look but it's still a bit more manageable than the above setup
I have 15x6.5 et40 rota grids with 195/50/15 toyos and 50mm lowered, personally has just the right proportions.
scaled.php
to fit any wheels in the arch without it hitting the arch or chassis, you'll have to consider the alloy width, offset, tyre dimensions & shape (when wheel's at full lock and/or suspension hit's bumpstop) , ride height etc
with this tyres outer dia, mine just barely misses the arch at bump stop and the inside chassis at full lock.
I think 15x8 might be abit too wide for the standard archway n may start causing conflicts without surgery
I had 15x7j ET40 Front and 15x7j ET24 Rear Flashbacks on mine with 195/45/15 Nangkang NS2 tyres lowered approx 100mm. It still needed the Whitline Panhard Rod tweeking abit though
In my opinion 15s suit the K11 best. I like 13s and 14s on K11s,but you've gotta have serious lows to pull it off
