roof rack
CMF_Mike R
I made use of a old gutter mount roof rack , I put some rubber inner tube on the feet and then I mounted it in the roof grooves , then pulled it down with the aid a racket strap , the strap is anchored on the seat belt mounting , the 2 side bars drop onto some bolts mounted verticaly in the roof bars , once on, the rack is quite rigid , then as a finishing touch the bars are cut to 3 foot long so that they fit in the boot between the rear wheel arches
CMF_Mike R
yep , just pulled down with the straps , but i can certainly rock the car by holding onto the roof rack and nothing budges either ..
had look at some of the products offered for the micra , the rear bars certainly look like they struggle to stay on this model with the sealed rear windows ..
it certainly frees up the boot space , but I dont think I will be butting any ladders or canoes on it !!!!!
