Funny you should ask, I've been looking around myself :glance:
Sent off a couple of emails and this is the best i've had so far:
Hi Dave
Please find below the specs of the two cages we do for the Micra. They are both multi-point bolt-in cages.
Let me know if you need any further info.
Joost (http://www.safetydevices.com)
Micra Mk2 1993-
Multipoint bolt - in cage. Front cage penetrates dashboard. Mounts to shell at 17 points. Cage includes ‘X’ rear diagonals with harness bars and tunnel brace. Unique ‘X’ doorbars. MSA/FIA homologated. Certificate available from MSA tel.: 01753 681 736.
Front cage - £267.12 - RBD283SMU
Rear cage ( ‘X’ diag's) - £356.16 - RBD285SMU
‘X’ door bar N/S - £81.62 - RBD28DXUN
‘X’ door bar O/S - £81.62 - RBD28DXUO
Front Strut brace - £144.16 - RBD280SBF
Micra Mk2 1993-
Derived from the D28 multi-point cage, specifically built for the 2004 Formula 1000 Rally Challenge. Consists of single door bars and available with single diagonal or X diagonals & harness bars in the rear cage. Not MSA/FIA homologated.
Front Cage - £161.00 - RBD373SSU
Rear Cage (single dia.) - £226.94 - RBD375SSU
Rear Cage (optional 'X' /H/Bars) - £296.94 - RBD375SXU
Single Door Bar Left - £46.20 - RBD37DSUN
Single Door Bar Right - £46.20 - RBD37DSUO
They have 2 fitting centres in the UK:
Nene Overland
Manor Farm
Ailsworth
Peterborough
PE5 7AF
Van Driel Engineering Limited
Roundham Road
Code:
East Harling
Norfolk
NR16 2QN
They are not Sparco ones, but one of their cages is MSA/FIA compliant. Their prices also include VAT. Worth a look :p
