Jay101 Black&Yellow Mar 6, 2013 #1 In the picture, the bottom right pipe coming out. Not sure if its a crank breather ....mine has snapped. Can these be removed and replaced. Or is it knackered? (not my rocker cover)
Rob Cosworth turbo'd 1.3 Mar 6, 2013 #2 Crank breather, goes to crankcase under the manifold. Where has it broken exactly? Broken flush with the cover?
OP OP Jay101 Black&Yellow Mar 6, 2013 #3 Yeh the one that goes underneath, its pretty much broken flush :/
Rob Cosworth turbo'd 1.3 Mar 6, 2013 #4 Maybe get some steel pipe and weld to it. Either that or find another rocker cover
OP OP Jay101 Black&Yellow Mar 6, 2013 #5 I could if welded it, apart from its a plastic rocker cover, thanks for your help
frank Club Member Mar 6, 2013 #6 just araldite some tube into it jay, there,s no pressure involved look (mine has,nt even got a clip on the hose)
OP OP Jay101 Black&Yellow Mar 6, 2013 #7 Ahh, didn't think if that. Or a smaller tube within a big tube possibly thank you
