CMF_Micralife » CMF Member Sydney, NSW, Australia Member since: Posts: Jul 11, 2013 #1 Hi I've just purchased some Steelies and the centre bore is to small. If I machine the centre bore bigger will it weaken the wheels in any way? Thanks Micralife
CMF_frank2 » CMF Member birmingham, United Kingdom Member since: Posts: Jul 11, 2013 #2 to some degree yes, what wheels mate ?
CMF_AB-NRML » CMF Member Perth, WA, Australia Member since: Posts: Jul 11, 2013 #3 What about fitting a 5mm spacer to get around that problem?
CMF_Micralife » CMF Member Sydney, NSW, Australia Member since: Posts: Jul 12, 2013 #4 frank2 WROTE: "to some degree yes, what wheels mate ? Click to expand... They are just stock steel rims. I would only have to machine out 2-3mm max, it's just enough to be a pain in the but.
CMF_Micralife » CMF Member Sydney, NSW, Australia Member since: Posts: Jul 12, 2013 #5 AB-NRML WROTE: "What about fitting a 5mm spacer to get around that problem? Click to expand... I'm not too sure how spacer work..
CMF_frank2 » CMF Member birmingham, United Kingdom Member since: Posts: Jul 12, 2013 #6 Micralife WROTE: They are just stock steel rims. I would only have to machine out 2-3mm max, it's just enough to be a pain in the but. Click to expand... i ground 2mm from my dub wheel centre,s np, with an angle grinder and a well worn stone
