CMF_Yom
» CMF MemberHey all,
Decided to revise my air intake setup! Why? Well I decided I'd remove the extra factory aircon fan from charlotte (it hardly ever turns on and it is snatching up valuable space for extractors).
Fan removed quite nicely, 4 screws. An annoying electrical plug (as per usual), jack the car up and slip it out from underneath. Put screws back in so I don't misplace them and re-attach splash guards. Easy peasy.
But then I noticed something else. I had a heap more airflow and a direct path to one side of the grille. Had a look at it for a few moments and I knew what I had to do.
Removed one horn and doubled it up with the other one. Sweet. Plenty of room for an induction pipe.
Pushed my existing intake pipe up to the grille under the aircon pipes and flattened the end bit so it was more of an oval intake (whether or not this does anything positive...). Stretched out the pipe to make it as smooth as possible and zip tied it to aircon pipes.
Stood back and admired. Sweeeeet. Started it up and instantly the engine note was different, i could hear the intake noise much clearer and it sounded so good (despite my air filter being due for replacement).
Haven't take it for a spin yet but I'm planning to and I can't wait to feel the difference (if any).
So here are the pics.
Before:
Before:
