My reverse light has stopped working - i know it's not the bulb as i checked it, then changed it anyway. Is there a fuse just for the reverse light? - all other lights work.
I had a problem like this and it was the connecting block between the light loom and the light unit. The pins were not touching, bent them over slightly to make contact and added some silicone grease. Fixed!
Its the reverse light switch which is located on the underside of the gearbox,
must be a common K12 problem as I've seen many threads having the same trouble.
