D
Deleted member 31521
Hi im currently looking for a few parts to assist me in the replacement of the gear shifter mech.
What I need to know is what parts of the exhaust should I have on hand
Going to have to drop the exhaust from the mid section to allow access and I sort of have an idea what bits i should be getting but I'm having trouble locating and being ultra sure that i have all the bits I will require to make it possible for it to be reinstalled correctly.
the mid section of the exhaust on visual inspection is in great condition of what I can see.
This is what I have found so far
Exhaust Gasket
Copper flashed manifold nuts (For easy removal later if needed) -- (and possibly for removal of manifold to get at bolts I want to remove for heatshield)
Manifold Gasket.
Do I also need a crush gasket and any special bolts with springs Im finding this part confusing as to exactly what I may need so I guess this is the main question I have for now.
Manifold Gasket.
Image of the exhaust diagram with pointer showing what may be nearest removal point for gaining access to the shift mech.
Hopefully this will be all I need along with some adhesive to re-fix the plate under the mechanism
Edit :- Exhaust Fitting Kit fits NISSAN MICRA K12 1.2 03 to 10
Klarius Exhaust Gasket 410485
So far have received the exhaust fitting kit.
Its got no springs and no nuts.
Seems to be four bolts 2 are shorter ones those must be for the hanger I guess.
Seems like it's only half of a kit to me a kit would contain all the items to refix an item.
The Klarius Exhaust Gasket 410485 is not needed for this but may be nice to have on hand incase I notice any leeks at or around the backbox section.
Edit :-
Enough guessing here is what I will most likely need
2 pairs of the kit shown so 4 M10 bolts and 2 gaskets
Lastly the copper nuts since these wont rust/fuse like standard ones.
Now i dont think im buying a kit twice so here is the (Diameter for the gaskets)
Might be useful if anyone is interested to know dimentions
Wire Ring Exhaust Gasket
45mm inner
61mm outer
15mm height
Exhaust Gasket
Manifold Gasket.
Manifold Gasket.
Edit :-
45mm inner
61mm outer
15mm height
