drand
1st Micraversary!
Right.
I've taken the old hub off but I cannot get the lower mounting nut to tighten - it just spins. I read through the Haynes before I started and it just says "locate the hub carrier on the lower arm ball joint". Does that not mean put it on loosely? I can't believe out needs to be pressed in.
If anyone can help asap i'd be very grateful, need the car tomorrow.
Cheers.
Cheers.
