Hello. Lots of minor problems stacking up with my beloved Micra. At this point its starting to bother that there are so many things not working. Would like to repair myself to save money and gain knowledge.
Does anyone know if it is possible to replace radio antenna aerial base without removing roof lining? Exact model is 2007 Nissan 4D MICRA HATCHBACK 1.2-FBAK12/243, K12. Radio code request also posted to official radio code thread.
Second question, license plate light module has corroded due to constant moisture buildup, have you guys applied silicone sealant to the edges of the transparent plastic part on top of license plate light? Does it hold? Have you applied non-factory lights, such as LED strips?
Third: trunk used to open itself continuously during driving. Lock would open itself nonstop like 30 times per minute, and then sometimes it would work normally. Sometimes it wouldnt open at all. Now its completely dead, has not opened for a year. Can be opened with screwdriver if getting inside the trunk and manually triggering the lock mechanism. Would this be a issue with damaged wiring on top corners when trunk is opened? There are some wires inside rubber protective casing. Rear wiper blades also trigger randomly when using front/main wipers. Could be a fault in same wiring..?
Also need to replace washer jet tubing as it is damaged, getting really poor pressure from jets. Probably not blockage since I have poked the jets with a needle. Has anyone done this, any tips?
Thanks.
Thanks.
